DailyDriven'07
Motor swap has begun!
Plans for the motor are pretty simple: couple new gaskets, 60 lb injectors, 2.8 pulley, option b, dual pass endplate, phenolic intake spacer, make or modify a header, and engine mounts from a solstice. And yes I will retain ac.
Transmission I'm using is a R154 from a 1JZ supra. I didn't use an MA5 from a Colorado or Solstice due to them being fairly non existent in my area and this trans was sitting in the shop already. I'm using the bellhousing from a Solstice to mate the engine and transmission. I plan on using a vss sensor from jagsthatrun.com to produce a 4 pulse sine wave. I have to change the front bearing retainer on the R154 to the one found on a MA5 in order to mount the slave cylinder. The clutch I'm using is the GMPP LSJ one.
For the fuel system I've got a fuel cell, walboro 255lph in line pump, LS1 corvette filter/regulator, -6an line and fittings. For exhaust I'll probably run 3" with a resonator and quiet factory style muffler. I'm doing all the wiring myself, I'm using the factory PCM with VATS disabled.
There's plenty I've skipped but that gives you an idea of what I've got going on. I'll update later to document my progress to date, but I did get the engine mounted. It surprisingly mounted on the stock ranger mounts.
DailyDriven'07
DailyDriven'07
DailyDriven'07
DailyDriven'07[/QUOTE]
Whatever happened to this?
It's over halfway through the engine swap Jim. Wasn't too much interest here it seemed when I started the swap. I have been keeping pics and details on the swap that I'll share here soon. The engine is mounted, transmission is mounted, heater houses plummed, 5spd swap complete, clutch system made and routed, supercharger inlet cut, wiring harness under construction, and waiting on overtime Funds to start coming in next week so I can order my fuel cell and last bit of stuff for my oil cooler setup.
DailyDriven'07
Whats going on with the 94, is it dead? SVT about to get a second V8 swap, lol...
SVT
SVT
94 is alive and well with its 4.0. I had it completely done less than a few days and had an offer I couldn't refuse on the d35 so I sold it. So the 94 is sitting in the driveway in the air waiting for me to decide between a sas or d44 ttb setup. Oh an I put the glass fenders on so either way I'll be increasing the trac width. I can't keep up with you rick! I play with my jeeps too much lol
Looks like a lot of work. You will have a one of a kind Ranger for sure. What was it about the FR500 wheels that you didn't like ? They sure looked great.
I loved the rear wheels. I could never get the front to grow on me due to the lack of a lip/offset. I'll probably end up with another set. If I do I'll order 2 sets of rears
This motor runs like its got 50k on the clock, but rust is eating the passenger side so bad that #3 spark plug rusted to the head. So I'm pulling this engine and installing my mustang motor with the M122 on top of it. I have in my collection a teksid that i will be building to ultimately reside in SVT's new frame/suspension/axle setup. Hope to get started on that this summer...
SVT
