- Aug 8, 2007
- Age
- 39
- Manito, IL
Made it to autozone. Here's the list of codes:
P0141 - Heater condition (Heated oxygen sensor - Bank 1 Sensor 2)
P0453 - Fuel tank pressure sensor condition
P0443 - EVAP purge/vent solenoid circuit condition
P1504 - Idle air control circuit fault
P1451 - EVAP system canister vent solenoid circuit malfunction
I'm not worried about the EVAP stuff. The IAC fault is probably what causes the low idle - it shouldn't effect normal operation of the engine right? Just at idle?
Which sensor is the o2 sensor code referring to? I only have one one each side, just after the header flange. It says "bank 1, sensor 2". Is it referring to a sensor that would be after the cat? If so, would it throw off the engine performance if it was gone? Cause I don't have one. Didn't have one with the 3.0 either.
edit: did some research. The P0141 code is referring to the downstream sensor - which I don't have. That's good since there's no more codes for the upstream sensors - they must be wired correctly and working. Bad news is I still don't know what's causing the engine to fall on its face.
I don't think the charging system is working either.
