- Aug 8, 2007
- Age
- 38
- Manito, IL
wow, you put a LOT of work into that. being able to crawl without touching the gas makes it all worth it though. if you get that d20 in there your crawl ratio will be .3 higher than mine lol.
I now have 6k miles on my doubler and no problems so far. I took it out for inspection this past weekend and the ATF was still red as can be, no signs of excessive wear, etc. I think it's gonna last a good while *crosses fingers*. I'm in the process now of the 63" chevy spring swap as well as designing/building a traction bar. the added torque was too much for my stock springs and blocks and I now have HUGE amounts of axle wrap. I think I permanently damaged the springs from it. hopefully the chevy springs and traction bar will eliminate that problem.
