D44/D35 mod
http://www.therangerstation.com/Magazine/winter2007/44knuckleswap.htm
Right here (just over 1/3 the way down) it says:
To accommodate the 44 upper ball joint inside the 35 beam some material must be removed from the inside of the beam. Depth of cut is easy to see from the pictures. Basically the thinner layer is ground off flush.
My guess is it's because the D44 knuckle is just a very slight hair wider than the D35 knuckle... That or maybe it's something related to the different type camber bushing used (tapered-stud vs. straight-stud).
