- Apr 28, 2024
- Age
- 39
- California
- 2.3L
- Automatic
- Total Lift
- 5" front Mid travel
- Total Drop
- 1"
- Tire Size
- 33
- My credo
- life is 10% what happens to you and 90% how you take it.
having some compression issues with my '97 2.3 xl took cylinder head off to get resurfaced, machine shop says its no bueno, cant resurface.
find a junk yard '96 2.3 xlt. great condition. get it home and cleaned up and install it.
no start. engine will crank but not fire up.
removed sparkplugs from one side and they were wet and smelled like gas.
i was stupid enough to not check the vin (but can still get it) and did all that work and was not leaving that junk yard empty handed.
old head is still; at machine shop. not sure if it is the same part number.
auto zone had the replacement head numbered 2fm1 and this new head is not.
be gentle
(p.s. i originally took it to the mechanic at the corner of my street, moe, i will not be doing any business there again. as the lucky ones that have had the opportunity to work on the 2.3L "lima" engine know all to well that it isn't an easy task to disassemble and reassemble. long story short. i got my truck back missing gaskets and bolts and turned every way but right.... just a fyi)
be gentle
