Cut fuel lines on project truck
Chommers
ASE Certified Tech
Picked up a buddy's neglected project. The fuel lines have been cut, and portions misplaced, because he was planning to box the frame. Hoping that someone would be willing to help me with a picture of the fuel line routing. This truck is an 88 with dual tanks and a 2.9L. I've already repaired the two lines from the tank selecting valve(not sure if that's the right name, has 2 lines to each tank and 2 lines to a bowl thing). There are 2 more i need to fix, one from the fuel rail and one to the fuel filter, both go the bowl thing on the frame rail and are 5/16" but have different size fittings. Really would appreciate it if someone had a picture or even could just look and tell me whether the fuel filter line went to the top or bottom fitting on the bowl thing.
went to the junkyard and looked. problem solved
