Current Speed Limits - How Does It Handle
wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
Southwestern Idaho
2.9 V6
Total Drop
215/70-R14
19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
Ok, so when the 80's Bronco 2 and Ford Ranger were made most highway speeds were 55mph, some were 65mph. Many places today are 75mph, and a few places are now 80mph.
So with that, how well do these older vehicles handle driving these higher speeds for long periods of time? I'd like to take my Bronco 2 out of state to a few different places for vacations, sight seeing, etc. It won't be for a while as I'm stopping at just the transmission rebuild that I have the cash saved up for, and right now I'm not wanting to replace engines or transmissions just to drive around at the current speed limits. Are there any actual issues related to driving these 75mph speed limits? I know my 88 B2 will do it, but any problems with engine and transmission by doing so?
I won't be towing anything with the B2 just a passenger or 2 and of course the normal travel items when going out of state.
I'm not sure there would be any problems to the drivetrain, perhaps slightly elevated wear rate. BUT you're mileage will drop into the toilet at higher speeds.
As with any vehicle fuel economy drops after about 55-60mph.
Thanks for the reply. I was more concerned about the wear and tear on the drive-train than economy. I assume that having the newer B2 that has the overdrive transmission would help a little, but at 75-80mph it wouldn't be much LOL.
Looking to drive from the Boise, Idaho area to Twin Falls, Idaho occasionally which is about a 2-1/2 hour drive and all highway/freeway so 65-75mph the whole way, although East of Boise there's a pretty long stretch where you can drive 80mph. Not a race by any means, but don't want to poke along at the ole' 55mph either and be passed by every vehicle on the road LOL. I used to just set the cruise control at 65, may still do so but 70mph is now the max speed for 18 wheelers so I'd guess I'd better at least keep up with them HAHA!!.
Nah it's fine. My truck won't make it past 65 because of the MRL unit, but that is the top speed in PA, except for a stretch of I-80 that I don't take unless I am heading to Punxy or Erie, and I don't take the truck on those trips. I also get a nasty vibration around 75, but again, the MRL unit and speed limits make that unimportant. I've had my BII up to 80. Turns felt weird, but it didn't roll.
Other than the reduction in fuel economy, sounds like nothing to really get worried about. The 84 B2 I had, I drove it out of town a few times but not on the freeway, so it only was running 65mph on those trips.
They get a little twitchy after 75-80, depending on how good of shape your steering/suspension is in.
The service truck at work is the same way, but it starts at any speed above 60mph LOL.
Still seems like my B2 takes longer than it should to get up to speed, felt like my 84 with the 5 speed manual was much quicker. Must be the sluggishness of the automatic that causes the slower acceleration.
Yes. I went from a 5 speed to a C5 auto in mine, and it felt like the 2.8 lost 50 HP. I couldn't spin a tire on a gravel road anymore.
Ok, so apparently going from the manual transmission in my 84 B2 to the auto in my 88 B2 is the problem. Maybe someday I'll swap...but if I do that I want to do the Cummins 4BT and get rid of all the electronic crap LOL.
2wd '92 runs good and handles just fine at 80. Tires don't like it much, but the truck will do it all day and handles just fine.
Sent from my XT1254 using Tapatalk
83 2.8 c3 auto. No issue doing 80mph but it sucks the fuel doing it
Sent from my SAMSUNG-SM-G891A using Tapatalk
I think any vehicle past about 55-60mph just burns a ton more fuel.
Well I haven't done much driving out of town yet due to having other things I want to take care of, but hopefully here soon I can get it out on the highway more. Just seems sluggish but from another thread its all boiled down to the automatic transmission which I guess is pretty normal for these and the rangers back then to be really sluggish compared to the manual transmissions.
I've owned every engine and tranny combination of ranger/bii from 83 to the early 90s and never had an auto the felt sluggish to me. Standards definitely feel like they get more power to the ground but even this old.83 im.driving now with the c3 will chirp the tires if I stomp it from a stand still. I run 60 miles one way to work around 80mph and it never skips a beat. But it is only getting 13mpg doing it.
A 5 speed doing 80 in the same truck would be getting me around 16 (as past experience shows)
No overdrive kills the c3 and c5 for highway driving.
My bii has a 4.0, with a 5 speed, 4.88 gears and 35s also has no issue running 80 down the freeway.
Hmm, maybe I should run it back to the transmission shop, I had a 1984 Ford Ranger 4x2 with the automatic and 2.8L V6 and if I recall it seemed to get up and go faster than my 88 Bronco 2, wonder if something isn't right in the new transmission then, it just seems like it should move faster than it does, unless I have brakes dragging, which reminds me I never did check out the rear brakes, guess I should do that first when I get it back this weekend.
My 2.8 was literally dying (blowing oil out the dipstick tube) and the trans still shifted pretty snappy.
Of course it is all relative too, compared to a new trans of today auto's from the 80's are from a different world.
