Cummins swap done, need tach signal help
The factory Tach on ALL EFI rangers is not run off the PCM, but off a specific tach signal from the ignition module. That signal is also sent to the PCM, but it is generated by the ignition module.
AD
I thought that they integrated the ICM into the PCM on the later ones. (I know they did one the '96+ Explorer.)
Sweet truck after i finish my 347 swat a want to do a 4bt swap in a 94 ranger 4x4 sas do you habe any vids of it running?
what tranny are you using behind that 4bt
