zachis4wheeling
So I'm gonna rip apart muh Ranger this weekend. Gettin started on puttin the tons under it. I'm thinkin out my options for the rearend. At first I wanted to inboard Chevy 63's or Toyota springs underneath the frame in the back instead of on the outside of the frame. From what I've seen on here from other dudes doin, Sasquatch Ryda, Woods-Rider, etc., it looks like it actually flexes well with this swap But I got thinkin about it, and since this is gonna be a crawler only, for off road use only, I think I got an idea that may work even better for more flex.
I plan on boxing the frame front to rear as it is, as well as ditchin the plastic fuel tank and settin up a fuel cell, so picture this and let me know if you think it would be worth my time;
-remove the stock springs and hanger/shackle assemblies,
-remove the stock fuel tank
-box the frame
-using the stock front hangers and rear shackle hangers, mount those the same way they are on the frame, just on the OTHER framerail on the boxed inner section you added, this way, makin a spot for yur new leaves. If my calcuations are correct, this should move the leaves in about as much as you probably can, while still not gettin in the way of the 14bolts pig I'm putting under there.
Now before anyone goes tellin me I shouldn't be drivin this prick on the road after I do this and blah blah blah, I don't plan on it, so rest assured. I am just trying to figure out a way to get some mad flex out of this thing in a way that normal joe blows can do that like myself, are on a tight budget.
I realize that there is gonna be some really big twistage of the springs happenin, but I think that if I put articulating leaf spring mounts/perches on the axle, that they might help.
Anyone have any comments on this?
-box the frame
