JibbaJibba56
I the bumpy lumpy rough idle and my truck will stall when I am cruising on the highway. I can shove my foot on the gas all the way when I catch the rpms dropping to zero and this still doesn't recover my truck. I had the engine scanned recently and it took me to a bank one problem of 4 things, spark plugs, wires, O2 sensor, injectors. I replaced the plugs and wires, didn't really want to dig into the injectors (I have been using cleaner on them) but I did notice that my O2 sensor has basically been messed with before (I recently acquired the truck). The nut was stripped to nothing and the housing was damaged to say the least. Could an O2 sensor make it that bad? I had it replaced this morning and the stall at highway doesn't occur but idle is still garbage. It will stall when i take it out of gear to coast to a stop or during moderate braking.
Also, when I did the plugs and wires everything worked the same as before I did them and trust me these things needed replaced as some of the plugs no longer had tips on them and the wires would crumble in your hand.
Please help me out.
Please help me out.
