Lead Head
- Nov 19, 2008
- Automatic
Had the exact same issue with my truck. Exact same.
Still not entirely fixed, but I narrowed it down to a dead lift pump in the fuel tank, which I believe is causing the frame rail pump to cavitate causing air bubbles in the fuel line. Put your fuel pressure tester on, hold the release button while you have somebody crank the truck. See if you get an abnormal amount of air bubbles.
Also, a blown/ruptured regulator will not hold pressure.
