Yes, the switch to TPA method(torque plus angle) takes friction out of the equation when tightening head bolts.
Thread and shoulder friction varies from bolt to bolt, hole to hole and when you get above 50ft/lbs, the TPA method keeps pressure more equal as the point of "torquing" a bolt is to stretch it a specific amount so it has the same holding pressure as the other bolts.
TTY(torque to yield) bolts/method means the bolts are stretched almost to the point of "yielding", failing, this means they will hold better with less variance when heated and cooled.
It also means you shouldn't use them again, or you may find the "yield" point when tightening or after a few heating and cooling cycles of the engine.
Older head bolts were stretched as well but not as close to the "yield" point, but as most older mechanics know, if you were reusing head bolts you made darn sure the threads, on bolt and in hole were clean and oiled, and even then you might have one break on the final torque sequence, lol.
There is nothing quite as unpleasant as having to spend the $50 anyway and then spend another 8 hours for the privilege of NOT saving any money
