coolent lines/belt length 5.0
alaskan155
washington
was looking at my 5.0 yesterday and i was trying to figure out how the heater core/intake lines are hooked up for the coolent.
the water pump has 2 hookups for coolant lines, the intake has 2, (figured out where top one hooked into lower manifold), the manifold has 2(found where 1 hooked at), and the heater core as 2 coming from the firewall
so if anyone has a picture of a stock f150 setup i would be mutchly apprecciated.
as for the belt, wondering what the length is for a stock 91 f150 serpintine setup,with out the smog pump is.
thankyou
I have a 96 i can take some pics of for ya. Not sure if this will help
it help, thank you, i see the 1 heater core hose T's and feeds the top of the TB, then goes to the water pump, but my ? is where does the other outlet go on the water pump?
For the belt lenght, just take a wire and install it like your belt and measure it. By memor, it's something like 89 inch without the air pump. Here is the part number from NAPA 060882
