Coolant Flush (LOST NEED HELP)
Hugh Januss
San Diego CA
Hi quick question I'm about to do, a coolant flush but i came across something that was a bit different then other ranger's i have seen (not many)
[/URL][/IMG]
I found the heater bypass valve on the passenger side but unlike the one that is circle'd in red in the picture above
my bypass valve ( below ) also has two other hoses connected as well so i cant simply replace the valve with the hose Tee that is needed in order to flush because then the other two hoses would be free? (not sure if that would pose a problem in flushing the coolant?????)
if i could separate the hoses (temporarily) so their individual that would be awesome, just not sure which hose goes to wear?? and deff dont want to guess and cause some serious damage
completely lost and confused could really use help! thanks!
(its a 96 4.0 liter v6 ranger)
Please refrain from double posting topics in multiple sections of the forum. If it is urgent enough that you feel multiple posts are needed you can make a single post in the "Urgent Help Needed" section or consult with a local professional.
Answered your question in the original thread BTW.
