Compressor is dying, what to replace?
exbass94
Guilford, CT
The A/C compressor in the Explorer is dying. Specifically, the compressor clutch is dying. When you turn the A/C or defroster on, the clutch just slips and makes a burning smell. Since this is the original 16 year old unit with 151k miles on it, I think it'd be best to just replace the whole compressor. For now, I've disconnected the wire on the compressor so I can still use the defroster. But, it's starting to make noise all the time when the engine is running, even with the wire disconnected. (Compressor might be starting to seize?? :dunno:) This problem has JUST started, and the truck has only been driven a total of maybe 30 miles since I've noticed this problem.
I will also most likely replace the lines. One of them has an oily residue on it, which makes me believe it's leaking. The system needed to be recharged about 2 years ago and has been fine, although last summer the A/C felt really weak. However, the lines are sold as a complete set, and they're $80. So, I'd rather not replace them if they're fine. I guess I could have the shop test it and see if they hold pressure first. Thoughts/opinions on that?
Anything else that should be replaced? I want the A/C working good as new again, but I can't afford to dump tons of money into it and I don't want to replace parts that are still perfectly good.
fix it all
look,if you replace the compressor,and your lines are leaking,you're going to ruin another crompressor. fix it all together.if you dont have the money,save it up and suffer 1 summer.its better than blowen money out the window.:icon_cheers:
Find out wha labour is on a AC pressure test. If it's say half shop time then your already looking at $50 at which at which point you may need new AC lines anyways. I say just replace it all, start with the compressor. Then ge a full flush when you replace the lines.
Or start simply and just try to re-oil the compressor and see if that shuts it up.
Well it seems my compressor is seized, which means I'll have to replace the accumulator and condenser as well. :sad: I have the money, I'm just not really willing to spend it on a spare vehicle that I don't really need, that's worth no more than 2 grand.
I installed a shorter serpentine belt that bypasses the compressor and I'm just gonna run it like that for now. If summer driving becomes really unbearable, I may reconsider repairing it.
