The engine temp sensor is fairly easy to get to if you remove the throttle body and thermostat housing. Both are easy to do.
freedom5
freedom5
freedom5
I broke one bolt on thermostat housing. I wish i had the guts to take off my plenum and give it a good cleaning. but im scared ima break some bolts along the way
Thanks for the great post! Wish I had your attention to detail. I have had my ranger since Nov '92. Kept her clean, and maintained well with plugs, wires, filters, etc. Yesterday she failed me. Started really rough idle, then stalled when I took my foot off the gas. Started back, very rough idle, and I limped her home. Today, replaced plugs (only 25K on old ones), wires, and air filter. Here is where ( I think?) the wheels came off; I removed the A/c compressor, lines, condenser, and tube shaped vacuum "thingy", before I started the engine. She started right up, but was erratic, fluttered, and barely idled. Should have left the A/C stuff till she was running normal, but I felt froggy and jumped to soon! I used starting fluid, and found no vacuum leaks. I pulled the PCV, and she idled better. Cleaned the pcv, no better. I then traced one vacuum line to a 3x4" inch part in the firewall. Pulled the vacuum, and she ran better again; plugged the line back up, no run. Seems like the engine wasn't getting air unless one of the 2 lines were left off? Any suggestions for this novice mecneck?
Since the 2.9 doesn't have a PCV, it shouldn't really have a bunch of build up.
