coil spring ????
oem 150 1.25 in spacer and extenders
ride height with leafs and 44 in tires.....actually lower then ttb setup on 35's
Is your truck alignable? If yes, no need for RA drops, if no then yes you need 'em.
my front dshaft hits the ra xmember at anything offroad...on road its fine, but it hits even with sway bars connected
:icon_confused:will this work to fix my front end alignment
Moog Alignment Caster Camber Bushing
Your Price: $24.98
Quantity:
Part Number: 5515-07056196
Notes: Caster Camber Bushing -- Frt Susp; 4WD; adjustment range -3-1/4 to +3-1/4 deg :headbang::icon_hornsup::3gears:
[/IMG]
yes,you'll need 2, one for each side. Those are the adjustable ones.
