Coil Spring Codes???
ShiftRacing
I have a 1998 Ford Ranger XLT 2WD 3.0 V6 Flareside, and I plan on putting some different tires on it soon. But first, I wanted to replace my entire front suspension because it's just worn out. I have the upper and lower control arms already, as well I have the shocks picked out. The only problem I'm having is getting a hold of the front coil springs. I keep seeing that you need a code to get the right spring, and that code is located on the inside of the door. From what I know, the previous owner got into some type of wreck and had the door replaced and painted, along with some areas. Would anyone know what kind of spring/spring code I would need to get to replace these? I included my VIN number below.
1FTYR10U0WPA67117​
Thanks!
Call a dealership up with the information you just gave us and they will give you the correct part # for your coils. RockAuto might also have new OE size coils.
I found some type of sticker on my driver side door I thought meant nothing really, but would this tell me the spring code??? I can't get a url of it, but I can e-mail or text it to one of you guys. But I'll put below how it reads...
Calibration
ETALONNAGE
8-56F F8AE-6E061-CGG
