- Aug 26, 2008
- Rainier, OR
who ever your mechanic was, totally incompetent. you should get half your money back for them not doing it right. then when you do it yourself go back and tell them it WAS air in the system. or you could show them these steps and make them do it for you for free
preliminary step: get an assistant, a quart of brake fluid, a drain pan, and basic hand tools
step 1: unbolt master cylinder and secure in a slighty upward position or jack front of truck into the air. a trailer MIGHT work but it depends try to do it facing up a hill
step 2: fill reservior DOT 3 brake fluid and place assistant in driver seat
step 3: crawl under truck (making sure it will not move in any way), and follow the clutch line down into the slave cylinder and locate the bleed screw above the line. it should be a 10mm.
step 4: put a box end wrench on the bleed screw and crack it loose then snug it back up
step 5: tell your ASSISTANT to slowly pump the pedal up and down about 3-4 times and then hold the pedal to the floor, then YOU open the bleeder with a pan under it and watch the fluid/air squirt out, then close the bleeder and repeat until no air comes out and the pedal feels right. the slave cylinder should now have full travel.
step 6: top off reservior and clean up
NOTES: don't let your assistant let go of the pedal until you close the bleeder or it will suck more air in.
keep an eye on the fluid level. with such a small cup it runs out fast. also make you pull the rubber cup out of the reservior so you don't end up wondering why you get no fluid.
make sure you wash any spilled brake fluid off painted surfaces or it will quickly ruin the paint.
