Clutch Master Cylinder line Ranger 96 4.0
Cheerios
Got into the truck stepped on the clutch and couldn't move it!
Slid under and saw that the disconnect to the release bearing had parted, Has anyone had this expeience?
Howdy and welcome to TRS~!
You mean the line that connects to the slave came out of the plug?
I've heard of that happening but can't remember what caused it...check the transmission section below and post questions there...typically, you can simply plug the line back in.
I do recall having a problem with one of my transmission lines (from master) that wouldn't stay connected...that was after I spent a few hours prying the little fingers off the ring in the connector so I'd damaged things...to fix that I had to make sure all the fingers were in place and the ring was back and then plug the connector in...the problem was it wouldn't "click" into place...
Finally got it back and was afraid to mess with it again...until I was able to replace the slave...
