clutch leaks like a siv
acidh3r3t1c
Des Moines Iowa
im going through clutch fluid so fast im about to mount the bottle in place of the reservoir and just change out the bottle every week right now im to the point of putting in fluid twice a day and i only average 15 mines of city driving a day this is getting quite annoying this also happens to my girlfriends truck which im going to be borrowing while i do my v8 swap i was wondering if this is a common problem and what might be the causes and how difficult is the fix
Slave cylinder. Have to take the tranny out. May as well do the clutch while you have it out. Just to make sure check all the lines and look into the tranny bell housing and see if the brake fluid is puddling up.
alright well the engine and every things getting pulled soon for the v8 swap so ill just add that to the list of things to do with the 2.9 setup once its out
i think ill just mount a bottle for the time being as a reservoir so i dont have to fill it so often
