clutch engagement problems
ddarkslayer
since I bought my truck when I depress the clutch slowly the clutch does not disengaged. the clutch only disengage if I snap the pedal to the floor quickly. do I have a bad master cylinder or slave cylinder or is their air in the system.
It's either air in the system, or something with the slave cylinder. Go ahead and pull your CMC and bench bleed it then gravity bleed the slave. If that doesn't fix it, it's probably time to pull the trans. and see what's going on with the slave/throwout bearing.
