Cluster Illumination, part failure
Cluster Illumination, 1/2 failure
1994 XLT inst cluster left half fails to light
I have pulled this cluster twice and I don't see why it has this issue. Replaced all bulbs. No obvious burns on the circuitry.
I drive this truck everywhere, and much at night, I must turn on the overhead light to keep up with the gas gauge.
Changing the cluster is an issue all its own, as it seems the 93-94 are only compatible. And mine has the tack.
In 1994 all 5 of the dash light bulbs use the same power source, Light Blue/red stripe wire, 3rd wire over on connector A(fuse 13)
No Series wiring so a burned out bulb wouldn't effect any other bulb
And each bulb also uses the same Ground wire, Connector B 1st wire Black
I would pull out the cluster again and use an OHM meter to test the unworking bulb sockets to Power-3rd wire and Ground-1st wire, then jumper to working socket as needed.
If the two effected bulbs are near each other then could be that just one Trace on the circuit board is bad, either the 12v or the Ground, so one jumper could fix both
