harriw
Hey Folks,
I'm looking at different hand siphon pumps and pros/cons of each.
Is there a good way to clean these things out well enough to be able to use a single pump for multiple uses (i.e. diff fluid, tranny fliud, motor oil, coolant, etc.)? Or do you pretty much just have to resign yourself to having a dedicated pump for each different fluid?
I'm wondering if I should go with the most versitile one (if it's possible to clean them well enough), or if I should find the best one for the immediate task, and worry about other applications later (if I wouldn't be able to use this pump for other fluids anyway)?
Thanks!
-Bill
Thanks!
-Bill
