Cleaning Fluid Pumps?
harriw
Western NY
Hey Folks,
I'm looking at different hand siphon pumps and pros/cons of each.
Is there a good way to clean these things out well enough to be able to use a single pump for multiple uses (i.e. diff fluid, tranny fliud, motor oil, coolant, etc.)? Or do you pretty much just have to resign yourself to having a dedicated pump for each different fluid?
I'm wondering if I should go with the most versitile one (if it's possible to clean them well enough), or if I should find the best one for the immediate task, and worry about other applications later (if I wouldn't be able to use this pump for other fluids anyway)?
Thanks!
-Bill
You talking about the style of pumps that go on top of a 5 gallon pail? Or just the hand pumps that you can use to suck out fluids and put fluids in?
Just the little ones for taking out fluids and putting them in. The one I got is like a liquid soap pump - screws right onto the top of the bottle of gear oil, and you press down on it like the soap to pump. I'm thinking maybe I should take that one back though and get one with just a length of hose on either end and a squeeze bulb in the middle, as it might be more versitile - but only if it's possible/practical/easy to clean it well enough that it can actually be used for different types of fluid without cross contamination. Not sure if there's a way to clean all that narrow tubing well enough or not?
Thanks.
-Bill
