Clattering noise from front end
Thrashingrage
Hey all,
For the last couple months, I've noticed a clatter from the front end of my Little Bronco every time I hit a bump, or if I'm driving down an even slightly bumpy street. It does not seem to be getting noticeably worse. I have crawled under there and shook the front axle shaft and the slip yoke makes a similar kind of rattle when compressed. Would the yoke make that noticeable of a racket on the road? Also, I believe that my two core support body bushings are shot, as are a few of my other body bushings and probably my radius arm bushings. I have replaced the sway bar bushings and am planning to eventually change out the axle pivots and radius arms with some Daystar polyurethane ones. What do you guys think about this rattle business? Also, what's the best way to change out those axle pivot and radius arm bushings? Thanks for the help and advice.
Josh
Radius arm bushings make a pretty heavy clunk under with an under your feet feel to it.It wouldn't hurt to jack up the ttb axle and make sure your tire doesn't wiggle at all.If your like me need to check those lug nuts too.
Thanks Trail B2, I'll check that next time I have access to a jack and garage, etc. The noise may be the radius arms, as it's a pretty distinct 'knock', but it doesn't necessarily feel 'under my feet'. I also checked lug torque just yesterday and they were all tight. Again, thanks for the reply and I'll let you know what I find out in a couple weeks, as I'm at school and am an hour and a half from home with no jack.
Thanks,
Josh
I'm trying to follow up a few threads that I started and never finished. Trail B2, thanks for the advice. Since this post, I have changed the radius arm bushings (the old ones actually weren't that bad, but I figured it couldn't hurt) and checked the ball joints; both sides are tight. Now as far as this "clattering" goes, I found out that it was the inner brake pads banging around. I took the truck to a mechanic a few months back for a brake job and either he didn't put the anti-rattle clips in or they were eventually spat out. Anywho, I ended taking a few things apart and putting new clips in there. Knock on wood, they're still in there and the brakes no longer rattle. Sorry for my extremely late response, and thanks for your help and advice.
Josh
