Chrwilkins30's build
Does that place sell the entire rebuild kit or just the syncros?
Also is there a way to tell how many teeth are on the 5th gear synrco without pull the thing apart?
Don't remember of they sold the whole kit or not, I just bought bearings and a reverse synchro.
For the fifth gear, there is no other way to check. Sorry.
Sent from my HTC ONE S using Tapatalk 2
Ill have to call them and see. Thanks for the info.
Got the shaft!!
Free shirt
Update on trans. After putting the shaft in and taking it for a drive it was still vibrating. When I'm coming to a stop you can hear it grinding until Im at around 10 or below. SO I decided to check fluid level since I know that it leaks between the extension housing and it had basically no fluid. Haven't check the fluid since I put the trans in 2 years ago. put a quart in and It was better went and go another quart and it was even better. Go figure. But its still grinding.(not surprised) and I can also hear the pilot bearing going out. So the trans needs to be pulled and rebuild.
By looking at the picture, seems like the pinion angle might be causing some vibrations.
I was wondering when someone would say something about the pinion angle. The pics are deceiving. The axle is set at 6 degrees.
Also if it was the pinion angle why would it start after 150mi.
Ok, was wondering. But, if I remember correctly, a double cardan shaft should be close to zero at the pinion..I think.
Yes I was correct, just asked my buddy, says ~0* for a double cardan and for single should be same angle at t-case and pinion so if you have 6* at t-case then you should have 6* at pinion.
Yes like the picture. When measure, its in relation to the driveshaft.
is there a good way to measure do that I get it as close as possible to be at the perfect angle. I will just order a pinion shim to correct it.
seems like a 4* shim would get it pretty close.
Yeah, pinion shim would work.
I ordered a 4* shim. Will be here tomorrow. I just estimated the angle it needed so I could be wrong, but if so Im only out $22. Even If its not enough Im sure It will vib less than it is now. Drove it to work and it Vibs worse on decel.
FWIW, I have the exact same axle seats as you welded at 6 degrees. With a 4" lift spring, belltech 6400's and no block, I needed to use a 3.5 degree shim.
Great build btw, keep up the good work.
Thanks Brinks! Got it all in a damn it made a difference. No more vibration up until the gauge says 55. Alot more drive able now. I needed to get a 6* shim to make it 100%. Ill probably wait a few weeks to install it as I hardly ever go over 55. I would post a pic but photobucket wont allow me to upload it for some reason.
Thanks Ben for the tip.:icon_thumby:
