Slayersaves313
- Sep 8, 2016
- PA
- My credo
- If it ain't broke, fix it.
I'm going to get to the point and before anyone asks "why on earth..." I have included the reasons below.
I want to put a non-Ranger truck cab on my B2 so I can seal the passenger compartment back up and pass an inspection (will be registering the vehicle off the cab's title so it's a truck rather than "sedan") bc I moved and would now have to trailer it to go on rides (and need to buy a trailer)
I'm also currently having electrical issues somewhere that my starter randomly engages. I'm going to remove all non essential wiring, install toggles for run/start etc and solid state contactors for main power and between battery and starter. I just need to know what I need to salvage from the bronco body for this. I'm a mechanic and an electronics technician so I know the idea, but I feel like I'm reworking the wheel at this point and could use some input.
Thanks,
Don
Some years back I came across the section here and on the bronco corral about chopping the top on my b2. Now, I was currently in an auto tech school and figured if I couldn't get it done right, I knew someone who did, plus projects could be worked on in class. I had my mind set but found neither assistance or support for my project so I got out a grinder and lopped off my roof behind the support beam.
Now, this isn't the prettiest thing I've seen and by no means am I sad that I did it nor am I happy with the turn out. I managed to get it inspected one last time after I did this with some quick fixes:
-Flipped over duff prerunner bumper to lower high to passing
-quick welded on a single pipe drop bumper to the rear bumper supports
-used a piece of vinyl board to close in the "cab"
I was told that this was allowed once bc the inspector was a friend of the family but I would need to figure out something better next time. So I mounted stainless studs along the lower window areas, up the support rail and acrossed the roof/roll bar and made a top from canvass and grommets (thus removable). The tops left ripping and grommets tore out, so now most of the year (minus the usual 2 rides I go on a year between repairs) it sits in the weather.
I want to pull the body and install a truck cab and short plank bed. My donor truck I have sitting is a 93 Isuzu pickup 5sp 2wd 2.3 single cab. The truck is low miles but I can't get the carb (yes carb on a factory 93 engine.. the only engine that was Isuzu rather than chevy) working and spent too long dicking with it so it's now parts donor.
Thanks,
Don
