mixwhit
- Mar 8, 2008
- Automatic
Ok, complete newbie question. '03 Ranger w/ the 4.0L and auto trans.
I just changed the transmission fluid and filter for the first time. Everything went fine (although getting that heat shield clipped back in place was a pain). I put 3 qts in as the Haynes said I should, and then as I checked it tried putting in about another 1/4 qt.
What's a little confusing is trying to get a clear reading from the dipstick. I'm used to being able to see a nice clean line on the thing from checking oil. But no matter how many times I wipe it and put it back in, I never seem to get a super clear indication.
This is while the engine is idling. What I'm seeing is it looks like fluid is in crosshatch area of the dipstick (pretty much to the top), but below the crosshatch area looks dry as a bone---until you get to the little curly at the bottom which has fluid on it.
With the engine off it reads between the holes (up to the top hole). And I measured what I took out and it was just a bit over 3 qts so my 3.25 qts in has to be pretty right. I took it for a ride around the block and it works.
So, obviously it must be ok. But I thought I'd check and see if anybody had an explanation for what I'm seeing.
