cheapest mods you have made to your rig
PaleBlue90
Solid Axle Swap
RBV's on Boost
Aurora Colorado
whats the cheapest, mod to your rig?
ill go frist
89 ranger-1.5 lift springs and coils (free) and chopped fenders/front bumper
90 ranger-HP Jeep YJ Dana 30 that was 20 bux with 4.10 gears
91 Suburban -many tree and rock shaped body modifications. they don't cost anything.
82 Toyota LandCruiser - converting the power steering to a GM saginaw pump, $5 for a mirror bracket the right length, pump was free, 7.99 for a belt. $3.99 for 2 compression fittings to adapt the toyota lines to the GM pump.
15" tire and wheel swap,daughter was dating a kid that wrecked his ranger.He said you want em?,come get em.Gotta love the cordless impact drill.
Most expensive so far.2'' suspension lift and duraspark conversion.
To me, the cheapest and BY FAR the best, is the throttle-cable-ziptie mod- virtually free
Other than that, level spacers from Fastnal (washers)- 20 bucks.
tail gate chains much cheaper that buying oem cables and i used plastic wire lume to wrap around chains so i didn't half to listen to them rattle every time i went over a bump.
and i had an extra bed mat so i cut it up to fill in the gap between my bed and bumper
black Rustoleum bumpers, grille, and wheels. Had the rustoleum sitting around, Therefor Free.
Leveling springs on the old B3000, I think I paid $18 for them.
id like to see what a rig would look like if everyone did a rig together
A blue anodized shifter knob...you don't know what it does to a woman to invite her into your truck to see your blue knob...is this the garage?
99 chrysler town and country- the spare tire carrier was rusted and the tire wouldn't drop. I had to cut the plastic dealie bob that holds the tire to the cable. Chrysler $350 for the whole tire carrier and winch.
I modified it with a short piece of stainless 1.5"x1.5" angle that was 7" long and a cable clamp, painted it with black bedliner.
cable clamp - $0.95
angle - $5.95
black bedliner - laying around in the garage.
been holding the tire up since May.
For me the cheapest thing I've had to do was grind the center yokes so the bleeding thing would droop both axles on a hill climb without binding and snapping a shaft--which I did.
attachment.php
a cigarette box, and some grease...homemade gasket!
bed-mounted the spare tire. sits upright in the box, secured to the side. had all the pieces laying around.
on the flip side of things, this was the most expensive mod. 150 bucks for a summit diff girdle cover. removed the stock spare carrier too while i was under there.
