cheap suspension lift
schneiderz
Alpharetta GA
Hey what is the cheapest way to lift my truck 2-3 more inches. I have a body lift already want to add in suspenion now.
spindles, i think fabtech makes some? search ranger lift spindles on google/ebay
Doestch makes some pretty good lift spindles too. I think they make them from nodular iron so it's really strong. I think they're worth checking out.
Fabtech or Doetsch makes spindles for your year. You can also get coil springs to lift it for cheap. I'd recommend spindles however, because they do not change your ride quality compared to coil springs.
Spindles will run you about $400 new (with shipping), springs will be about 1/3 that but if you go to tall with the springs it will ride like crap. 1 inch with springs is do-able 2 is pushing it, 3 needs new upper control arms $$$.
I just posted a thread about this, but check out suspensionmax.com
They offer a three inch spindle lift for much cheaper than fabtech or doetsch and from what I hear they are manufactured in the same factory as doestch (could be rumors). However I will have them on my truck either this weekend or next and I will put up a build thread and maybe you can check them out once I actually have them on my truck because I honestly have no idea of their quality. I do know that I could not afford the fabtech or doestch kits and this was a cheaper way of get the stock ride + 3 inches of a spindle lift
ok thanks I just went on that website and found some lift coil springs how much do I need to lift the rear if I lift the front 3 inches?
