Caster/camber replacement 1993 Splash, 2.3 engine, and 2-wd.
arseatea
Beavercreek Ohio
Anyone know what size or degree caster and camber adjuster I need for this 1993 Splash, with 2.3 engine and 2-WD? Checking on line, there seems to be a lot of sizes in degrees. I am pretty sure I will have to have a professional alignment when I finish. Is there a marking anywhere? I am pretty sure I will have to destroy the ones in it now and not sure I can read any marking that may have been on it.
You can't know which bushings are needed until you do what ever work you are doing and then put it on the rack and see how far out of whack it is. So the answer to your initial question, as asked, is "No", literally nobody knows which part you will need until the end of the job. If you are sticking with a fixed bushing that is.
If you get the adjustable ones and go with a good mid-range one, like a 0 through 3 or 4 odds are good you will be able to get it set correctly at the alignment shop.
What are you doing anyway?
1993 Splash, 2wd, 2.3 engine
Thanks for the post. I am beating my self up replacing upper and lower ball joints. I am using the directions in my Haynes Repair manual. So far, nothing works like the manual says. I was not able to remove the pinch bolt which threads into the twin-I-beam (or what I would call an axle shaft) that holds the upper ball joint and camber adjuster. So after oiling,beating, drilling, heating, I finally just cut the pinch bolt in the middle thinking that the two-piece caster adjuster on top would pop out. No such luck. I had to beat it out with a thin chisel and punch. So, now the upper part is loose and I am beating on the lower end hoping it will let loose of the lower ball joint shaft so I can take the spindle out. Then I will drill out both halves of the pinch bolt and replace it along with new Moog ball joints. But, I did notice that the new upper ball joint has a split shaft. Not sure if it is ok to use it or if they sold me the wrong one. I have an air hammer that I thought I might try to knock the spindle loose at the lower part of the I-beam.
What do you think? The nut is off, but it is tight as a drum. Really appreciate any help you may give me.
Finally got the ball joints out and replaced. I had to beat the I-beam yoke with a small sledge, but eventually the spindle fell out. My advice is don't give up. I have to put it back together and get the alignment done.
Axle shafts turn. There is nothing on the front end of your 2wd truck that can properly be termed an "axle shaft".
