aeidian
- Oct 7, 2010
89 2.9 4x4 5spd FM146
I swapped out my 70/30 bench for a 2 buckets and a center console. I used some bolts from lowes to attach that bracket for the console to the floorboard, but they were a bit too long, specifically right above the transfer case. The rear of the transfer case where it bolts to the drive shaft (I wanna say the yoke, but I don't know if that's the right term), the big ring that the bolts go into from the u-joint, seems to hit the end of one of the bolts when taking off in first. I trimmed the bolt down with a dremel, but it's still a bit too long, because it still hits. Seems like the drive shaft is tweaking when taking off in first and hitting that bolt, making a popping sound. It didn't do that before I put the bolts in, and I know it's hitting so I don't think it's the u-joint popping. Anyway tonight the truck started shuddering on take off. Revving the engine in neutral it didn't have an issue, it wasn't until it was put under load by being in gear did it start to vibrate and shudder. It does it in each gear, but lessens as I get to cruising speed. It doesn't stop completely, just lessens. Lifting the rear end and putting it in gear I can see the transfer case wobble a bit, and a bit of up and down play on the driveshaft. The bushing part of what I believe is the carrier bearing (center support bearing) seems a bit worn. Could a worn out carrier bearing be causing this shudder and vibration?
Also when I had the rear jacked up off the ground and in gear, one wheel spun, the other didn't. I didn't think that there was limited slip differential or whatever that far back. I can hold one side and the other moves, but then I can hold the other side and the one side will move. I thought they were both supposed to move all the time, is this normal for one side to move and not the other when it's in the air? I've seen front wheel drive cars do this, but on newer ones.
