Just FYI on electric fuel pumps and the Oil Pressure switch.
In the old days mechanical fuel pumps weren't really much of a danger because they were low pressure and would shut off when engine shut off, like in a rollover or accident, or hose broke, engine dies with no fuel
Electric fuel pumps are good but they present a problem in a rollover, accident or broken hose if they keep pumping out fuel, the danger is obvious.
So they have 3 shutoffs, the key of course, and then the inertia switch, it is suppose to "open" and cut power to the fuel pump(s) in an accident or rollover, it is basically an impact switch.
And the 3rd is the computer(which you are removing I assume), if engine RPMs drop below 400 then computer will "open" fuel pump relay cutting power to the fuel pump(s).
With a carb there is a float bowl that always has fuel in it for starting the engine, so fuel pump doesn't need to come on with the key, same as mechanical pump setup.
An oil pressure switch closes when there is oil pressure, engine running, and opens when there is no oil pressure, engine off.
So you add the oil pressure switch to the engine and use it to run the Fuel Pump Relay.
Very easy to wire.
And that gives you the safety back to the system.
