19bonestock88
- Apr 10, 2012
- My credo
- Plane travel? I'll do my flying on the ground, thanks!
A little intro...
The truck is a 1988 ranger, 2.0/2bbl, m5od, 2wd...
Back in april, i posted about killing the engine, only to find out that i wiped out the flat tappet cam... I swapped in a roller and kept going...
Anyway, i think the carb is about shot...
As some might remember, i pressurized the intake when the cam messed up, and the carb wasnt entirely right, but i ran it anyway...
It is now running so rich you can smell the fuel out the exhaust from probably fifteen feet...
It is becoming increasingly temperamental in cold weather, often requiring five to ten minutes of trying to start/ trying to warm up before it is remotely driveable...
Probably losing compression due to the insanely rich fuel mixture...
Anyway, i want to fix this issue while there is still a useful engine to save... I can buy a carb from an 80 mustang(i think its the 5200) for a shade more than the cost of the rebuild of the stock POS carb... I also have access to a free holley 6280 if that would remotely work(doubt it though)... Would the 5200 bolt to my current intake? Throttle linkage issues? Fuel pressure regulator needed?
All opinions and/or input welcome and encouraged!
Thanks in advance...
