cap/topper recommendations for 2003 B2300
nycb2300
Hi,
I'm looking for recommendations for a cap/topper for my 2003 B2300 (standard cab; 6' bed). I don't need anything fancy (fiberglass or aluminum would be fine).
Are my choices more limited than for the same year Ranger due to the flareside bed?
Does anyone have experience with the Leer 100R?
Thanks.
Fiberglass is heavier but isn't as prone to leakage as aluminum is.
Aluminum caps are easier to lift on and off if you need to do that regularly.
Aluminum caps are easily modified
(things can be mounted to the internal framing with screws)
In general Leer and Brahma are the best out there...
a flare side bed definatly limits your choices.
AD
