just an update... I got the new bushings in my truck when i got the old ones out it they didnt seem to be in that bad of condition but once i put in the new energy suspension bushing in it made a huge difference no more hopping from side to side when i hit bumps on the highway less sway when i get hit by a cross wind and less need for consant steering correction while driving..... so some tips for others that i learned while doing this project #1 dont do it just buy a new truck!!(this was a simple in theory job but a serious headache!!) #2 if you are thick headed enough to do it anyway make sure you have EVERYTHING you need before you start (breaker bar, lots of breakfree spray, tall enough jack stands, 6 new bolts to relace the old ones, grinder or sawzall, a drill with enough small drill bits, and some relaxing music cuz this job will piss you off) #3 do not do not do not use a torch at anytime!! the torch made my old bushings gooey and sticky and even harder to get out, also dont use it to help break free any nuts if you are using a sawzall to cut off the bolts it hardens them and makes them nearly impossible to cut #4 if you use a sawzall to cut the bolts which i had to do (cuz i dont have a grinder) go SLOW cut in intervals 15-20 seconds at a time or you will get the bolts super hot and they will harden and it will take like 30 mins to cut each side and you will got thru a lot of blades if you can keep the bolts from heating up which they do very easily you can get through the bolt in like 3-4 mins and not ruin your blades. #5 once you are ready to get the bushings out press them out or drill them out dont torch them it will just make drilling them suck and take longer and be very messey #6 dont let your axle get back to far while springs are unattached or OOPS your rive shaft will fall out and that just one more thing you will have to do to get everything back together #7 i just pressed the new bushings back in with a c clamp and two sheets on metel to put between the clamp and bushings it was easy with the lube i got with my kit #8 make sure you press the bushings in with out the metel sleeve al ready in there put the bushings in then put the sleeve in #9 bolt the front leaf in first!! #10 i guess you are supposed to tighten the bolds down after everything is put back together and you put the weight of the truck back on the springs
