cp2295
- Jul 25, 2013
- Washougal, wa
- Manual
- My credo
- If you ain't first you're last
So I took the tranny out to replace the flywheel, and so when I unplugged the clutch I had to remove the black retaining clip in order for the line to come out of the slave cylinder. So I got the trans back in and put the black clip back into the slave and now I can't plug the line back in. I can plug the line in with the clip off but obviously it doesn't stay in place. I have tried pushing it in while putting the clip on but that doesn't work. I remembered when I first put this slave in it said do not remove clip, and before it plugged in just fine.. Any help would be much appreciated at this point I'm thinking I need a new slave (this ones only a month old.. Had some issues with my new flywheel ring gear, that's why I didn't replace the slave).
