Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
OK, truck is all back together. What a PAIN that was! We played dances with engine for about 3 hours trying to get it to seat. We tried dropping the trans out several times and adjusting the disc with the alingment tool and it just didn't want to go home. I never was able to find a spring that would work for the shifter so I just cleaned it all up and put it away. The little plastic bushing broke as we were re-assembling the xfercase to the engine so we will order a new one. Taking the case off was not a big deal but working in the gear oil that spilled out SUCKED. bleeding the clutch also sucked.
So at this point, the truck is back on the road but needs the bushing replaced. I fixed all the wire hackery and found the reverse light switch is ALWAYS closed so I ended up removing the back up light wiring.
My son's next paycheck (Friday) he will pick up the bushing and the back up light switch and he should be golden! I appreciate you guys all kicking in some good advice! We couldn't have done it without you!
