Can a clean looking filter still be restricting fuel?
Featured Build Threads
Conflict
5+ Year Member
sc
  • Truck died while driving. No fuel pressure. Changed filter. Fuel shooting out of the schrader valve and truck runs fine. I can blow air through the filter easily. Open the filter and it looks clean. Could it still have been restricting totally? Every time I turned the key the pump was humming. Suggestions? Change the pump just in case? Look in the tank for crud? Tank seems plastic. Were they all plastic for 2wd manual 2001 B2500's? I'm tempted to remove everything and put in 2 smaller tanks with their own pumps? I don't like not knowing the cause.
Guess it's just like a fuse looking good, but being bad. Or a spark plug.
I recently changed my fuel filter, hadn't done so in probably 10 years. Could not blow through it.
What gets me is why they even need the secondary filter. There is a sock on the pump to keep it from getting plugged up. Despite that, the inline filter still gets plugged up. My three motorcycles have the pump filter only, no inline filter to be found.
Things That Make You Go Hmmmm.................................
At the same time as the filter, had a really dirty MAF. Spray wouldn't remove the brown stuff that was on the upwind side of the wires. Had to use a q-tip and alcohol to get whatever it was off. Felt kind of sticky. Don't know how that got there. New filter and clean MAF fixed it right up. Previously, the MAF was not working. If you pull the plug while the engine is warm and running, and it keeps running, the MAF is not working. Cleaned it and it works now.
so it's running now?
just looking for why it died?
try looking at the connector and wires attached to the inertia cut-off-switch.
if your pump is 25 years old I wouldn't feel bad about replacing it.
Featured Ranger Based Vehicle
