C4/C5 transmission pan
CUracing
Millersville, MO
Transmission pan off of c4/C5, good shape, light surface rust. $30 shipped, call or text 573-225-6108. Located in Cape Girardeau, MO
Umm you know you can buy a brand new one with a drain plug for 30 bucks right? :icon_confused:
The Ranger/Bronco II C5 pan has the hump in it for better fluid pickup when on rough terrain, not the same as a typical flat C4 pan.
The C5 also has a pickup built into the filter, I don't know how interchangable RBV C5 and "normal" flat C4 pans are. I also suspect the RBV C5 pan (only made 1983-1984) would be rather boutique for someone to be remaking them.
