- Sep 7, 2008
- Age
- 34
- lake havasu
- Automatic
i had some time to kill
isnt that holiday a long way awayhey I might have asked you before. Do you ever come up to PHX. I would really like you todo my d44 beams. If not I should be coming down that way Labor day. Needless to say I would like them done for that if i can. How long would it take to get them done?
pretty much if i limit one side an inch it gives the other side an inch more droop so limit straps should balance evrething outwithout knowing right from wrong here I'll ask this question:
through the use of bump stops and straps are you planning to limit the driver side travel to match the passenger?
my personal set none still waiting for coilovers iv bin way to buisy with work and doing a 4 link, trans mount, radius arms,engine cage, int. cage, and a set of c&t beams on a broncoSo how much time offroad has this setup seen?
there not the geolandersI never noticed this before Byron but we have the exact same tires, I never would've thought any one else had those... things![]()
my personal set none still waiting for coilovers iv bin way to buisy with work and doing a 4 link, trans mount, radius arms,engine cage, int. cage, and a set of c&t beams on a bronco![]()
but i did have a set of c&t beams and radius arms run in the parker pre run
