byrons "ranger#1" 4x4 long travel build up
i had some time to kill
what numbers you lookin at bumped/straped?
i gotta get glass for the bumped number but limited im going to pul l16 1/2 untill i hit fender and ill get about another 1 1/2 to 2 inches with glass
hey I might have asked you before. Do you ever come up to PHX. I would really like you todo my d44 beams. If not I should be coming down that way Labor day. Needless to say I would like them done for that if i can. How long would it take to get them done?
without knowing right from wrong here I'll ask this question:
through the use of bump stops and straps are you planning to limit the driver side travel to match the passenger?
So how much time offroad has this setup seen?
I never noticed this before Byron but we have the exact same tires, I never would've thought any one else had those... things:D
isnt that holiday a long way away :icon_confused: any way i really dont go up to phenoix much but i can have them done in 1 day
pretty much if i limit one side an inch it gives the other side an inch more droop so limit straps should balance evrething out
my personal set none still waiting for coilovers iv bin way to buisy with work and doing a 4 link, trans mount, radius arms,engine cage, int. cage, and a set of c&t beams on a bronco :annoyed:
but i did have a set of c&t beams and radius arms run in the parker pre run
So you're selling an untested product that has no time offroad whatsoever and claiming that its unbreakable?
