BW 1354 Yoke and Flange source
Damon Toth
Costa Mesa, CA
I am switching to a dana 35 and epo 8.8 and I need to change the driveshafts to the series 1310 .
What is the spline count and diameter for the front and rear output shafts of the BW 1354 and are the 1350 the same?
Thanks
26 spline outputs F&R (rear is same 1350/1354).
Are all 26 spline yokes the same diameter- on ebay there is a Spicer 20 for a 1310 joint and 26 spline would that work?
Thanks
The 26 spline shaft would be the same size, though I couldn't tell you if the sealing surface diameter is the same or not.
You probably would have to look up some part numbers to see if you can find a match.
None of your local wrecking yards have one?
