lifting the 98+ rangers is mall crawler turd polishing.
Mallcrawler?
gonna say I like the 08' with a lift on it makes it a little more easier to conquer the offroad events that require a little more clearence?
I gotta a FABTECH 3" spindles in the front and added a leaf in the rear I dont know how much more expensive the tortion bar setup would be?
you cant get that much travel out of the 98+ rangers regardless of how much lift you get. CVs do not do well in vehicles lifted more than a few inches.
IMO when you use a supspension lift on a CV equipped vehicle all you are doing is raising your center of gravity, making enough room for a slightly bigger tires and increasing your chances of a rollover. you dont gain much if any flex, LOWER durability of your CV joints, increase ball joint wear, steering wear, etc.
if you want a lifted mall crawler go for it but a rear locker will get you more off road capabilities than a 3 inch lift.
a lifted stock vehicle wont stand a chance against a stocker with a rear locker and some good stock size MTs or better.
unless you are playing in mud, tire size, lockers and travel means more than lift. NO you do not need your vehicle to ride much if any higher than stock to get more travel.
FYI i have less lift than you (2-3 inches), and run 33s.
86
Not arguing with you but how if you are higher off the ground do you not benefit by having more clearence and less of a chance scraping the bottom of your truck? My shits not a lifted mallcrawler either I actually take my truck out in the dirt and use it. It isnt just parked in the driveway after cruising the mall for females.
what about break over angles? Ex. cab trucks cant go places like ur BII 86
Thread hijack...
