Building a weekend warrior truck?
Cody Ray
Phoenix
I currently drive my 2001 2wd Ranger completely stock on the roads and trails north of Phoenix. It is quite a rush sliding through corners and flooring it down straightaways however after last weekend I need to do some modifications. I lost control of the truck and took it down into a ditch full of rocks/boulders that just about destroyed my rear driver side wheel.
Thank God I didn't blow out my tire, those Yokohama Geolander A/T held up pretty well. I feel that if I had some taller tires the rim may have been spared. Of course if my wheels had continued to remain in contact with the ground I might not of ended up in said ditch :blush: Wondering what I can do as far as springs and shocks that will give me a better ride a more travel? This will never be intentionally jumped and I'm not racing 500 miles through the desert. Just want to have some slightly more controlled fun on the weekends and camping trips.
Just springs alone probably won't give you more travel. If you need more travel, you'd be needing to get long travel control arms. Or you could get Fabtech's 5.5" kit for your truck. The kit comes with 3" lift spindles, 2.5" lift springs, and their control arms for the front. This kit may work for what you are looking to do. But then again, if you are already looking at the Fabtech kit, you may as well spend a few more hundred and get a Camburg kit which would probably be stronger than the Fabtech parts. Both of these kits will give you a wider stance and better travel, so yeah , pretty much what you want to be looking for.
Or just invest in some high quality shocks for a more controlled ride. Maybe something adjustable like a fox or foa.
