Bronco Rear Windows
ArubaBronco
Hi guys , im new here and decided to post a question to hopefully get some answers.
I"m restoring a Bronco II 1989 2.9L
I'm hitting a snag in getting the rear window seals , or any information about it
Im wondering if they use a single seal or multiple like one for the outside and one for the inside , and where i could possibly order these from , I'm in Aruba and its kinda hard to get parts here .
But i have some friends in the states that ordered parts for me in the past
so i would be able to get what i need
Any help greatly appreciated
Good luck. I just checked LMC's catalog and don't see anything. If they don't have it, you're probably out of luck. Sorry. I hope somebody else can give you better news.
The rear side windows or the rear hatch window?
The side windows do not have a removable seal the rubber/plastic is molded to the window. Your stuck getting new windows if your rubber is cracked.
the rear windows have the rubber seal molded to the glass and are attatched using studs and nuts and are sealed with adhesive on the inside
