- Nov 12, 2018
- Maryville
- State - Country
- TN - USA
- Drive
- 4WD
- 2.8 V6
- Automatic
Just to give you an update I just finished the one wire conversion tonight and let me tell you what an improvement the old alternator put out about 13.5 V at idle this puts out 14.5 the plow now goes up and down a lot quicker due to more voltage at the motor and at idle it is putting out a consistent 14.5 to 14.6 V. It was a quick install bolted right up in the stock location with the stock brackets lights are brighter. Everything seems to be an improvement over what it was. I am fairly happy right now. We will see how it goes when I actually have to plow with it.
View attachment 138937View attachment 138938
So, you used the alternator that you linked in your original post?
I assume you are running duraspark, what are you using to work an electric choke if you still have one? Mine us currently running off the S wire on the stock alternator I believe.
