Wanted Brake master cylinder plug connector
sexybluelady
springfield, ma
I need this plug for the dummy low fluid light that plugs into the brake master cylinder. I need the plug with enough wiring to splice it into my harness. Thanks
66547
Pretty sure this is the guy you're looking for
Have a similar but different harness problem on my 1990 2.9L auto. I need to locate the harness connector the reservoir sensor plug connects into. The only connector near the reservoir that has nothing connected to, but it only has two wires, not the three needed. I don't see any loose connector, but it must be there. Otherwise may have to splice into the harness, but then need to have correct wiring diagram.
Thanks in advance
Got any pictures?
