Bolt on spacers
cstishenko
Kelowna, BC
Anyone else having major wheel wobbling/ hopping/ vibration issues with bolt on spacers?
I'm not happy with mine at all.
I only now from my experience with my Toyota and I has spydertrax 1.5 spacers. Teu were fine need to be sure to clean everything under and torque the hell out of them
are they hub centric spacers?
Lug centric. I know....... ugh
im getting a wobbling and hopping feel in my seat and steering wheel. i am pretty sure its the spacers... but havent pulled them off yet because im running 33s on alcoas and i think it will rub.
Ive taken everything apart twice and re installed.
best i can say is pull them off and drive it.. even if it rubs a little it could tell you what's going on..
did you put the spacers on at the same time as the rims/tires? or afterwards? if you did it at the same time it maybe a rim or tire.. how's your steering parts? balljoints?
are they a 1" or 2" spacer? spacers put more stress on the balljoints and stuff so if you had slightly worn balljoints and then put spacers on it-- you could have multiplied your problem.
idk really, i'm just tossing out ideas seeing if i can help.
Thanks for the support gents :)
My truck is an 07 FX4 with 50,000km (25k mi) I would suspect everything is still awesome under there.
I have 2" spacers, and I had them with the factory 31's, Duratrac 31's, and now Duratrac 33's. Same shaking and hopping... it's just getting worse being that im on bigger tires now.
Is it possible that the spacer could have warped my drum? One thing I noticed the other day, I came screaming into my underground parking and laid into the e-brake to see if both were working.... And only one wheel locked up.
Now this could be that my brakes are just out of adjustment, or does this say something more serious?
on the e-brake; idk.... the e-brake only has pads on one side, maybe that's why. usually just the driver side i think.
the spacers shouldn't have bent anything unless you over/under torqued something wrong. idk. i'd get under there and see if i could find anything that wiggles/wobbles/shakes whatever..
get someone to sit in the truck and wiggle the steering wheel while you get under it and look around. see if there is slack anywhere.
did it start shaking when you put the spacers on? or afterwards/before?
Shortly after.
I have a feeling I know what I need to do... Pull the spacers off, and drive in a straight line to see if the shake goes away.
If it does. It's spacers. If it doesn't then it is down to drums/studs and or wheels.
or... the spacers put stress on balljoints or you have a bad tie rod end or something. idc what year it is... i put ball joints in a 2010 dodge ram last week. NEVER again! lol. but its a 2010 and it already needed them. so its possible.
Mostly coming from the rear though. I'll do some investigations tonight after work.
I have duratracs on my fj and I love them do you like yours?
im running 33's, and clear fine. you should be good if lifted.
i had a rear vibration. was warped drums. easy test: when driving at about 40, push down on your parking brake till you feel the truck start to slow. if the drums are warped, the shaking will get very rough.
You may clear - but you missed my statement. I'm on factory Alcoas, there is a 99% chance i'll be rubbing ALL over the place.
Your test for warped drums is very valid. However.. Remember that if the spacer is causing an out of round/ not centered situation this feeling can be nearly identical as warped drums.
What I would have to do is find a set of 33's on wheels that that are known good, without spacers and do your brake test for trueness. If they're true then I know it is spacers or wheels.
I have a feeling the drums are a little warped, but I have a feeling the spacers are bad too.
A buddy of mine who has the identical setup, right down to tires just put on a new set of AR Daytona steel wheels and all vibration is gone. He had the same vibes.
Now... Going to a 15x10, would I have to worry about blowing a bead when in the bush? I air down to 20 psi, not much more.
Or if going 15x10, should I consider bead lock wheels?
And if I go bead lock, will I be able to balance up the wheels?
I have no experience with locks/ wide wheels. I've always run tires too wide for my wheel (poor mans bead lock)
